My first backup was direct to Wasabi. Now I want to create a local backup with the same contents. I realize now I did this backwards. I used duplicacy add and duplicacy copy to start copying the Wasabi snapshots into a new local storage. Wasabi must throttle downloads though because I’m not getting even 8 Mbps down and I was saturating my 15 Mbps upload when I did the backup initially.
I didn’t want to wait for this, so I wiped out my new local storage, created a new one, and I copied the config file from the Wasabi storage into this new local storage. Then I created a new backup into the new local storage. Because the directory I am backing up didn’t change and the chunk parameters and encryption keys are the same, this created all the same chunks that are on Wasabi but instead of taking a week it only took about 6.5 hours.
(In reality what I did is slightly more complicated than this but the outcome is the same as if I had created a new local storage and populated it with the chunks from Wasabi - in the required unflattened form).
Now I’m running duplicacy copy from Wasabi to local and I expected it to fly because all the chunks it needs to create are already in the local storage. But it’s going very slowly. I looked at the network monitor and it’s using all of the bandwidth Wasabi will let me have, ~8 Mbps. So it must be downloading the chunks, THEN realizing that they don’t need to be copied because they’re already present in the destination.
I realize there’s no reason for you to have optimized for this case but it sure would be nice if it did things in the reverse order, checking for the presence of a chunk before downloading it.
This is what I see (excerpted). These lines tick by pretty slowly.
Chunk b461991e04a5b7ce7c159f43b278e3f8d13a2ee344aa9501656466e02282f939 (1/99775) exists at the destination Chunk 495fcf2e492b730a8a48d7e8c470455f4f777ef161308fd6bf25d612a206c435 (2/99775) exists at the destination Chunk 36f251c1a264e46a9098a7bcf9f4e6f942eda5695141b52f712831b9dfe4cfc5 (3/99775) exists at the destination Chunk d0fa2057cf94de04698f252bb283fb2fd67516829ce08c28acb66097f2d51717 (4/99775) exists at the destination
