When I start Duplicacy.app 2.1.1 I get presented with the following dialog
Dismissing the dialog closes the app.
It started after MacOS update. Machine hostname did not change.
Any ideas where to look for troubleshooting?
You can run defaults delete com.acrosync.mac.duplicacy License in Terminal to remove the existing license. After that, when you restart Duplicacy it will allow you to enter the license code.
