These builds are intended to be the 1.6.0 release:
https://acrosync.com/duplicacy-web/duplicacy_web_installer_win64_1.5.3.exe
https://acrosync.com/duplicacy-web/duplicacy_web_osx_arm64_1.5.3.dmg
https://acrosync.com/duplicacy-web/duplicacy_web_osx_x64_1.5.3.dmg
https://acrosync.com/duplicacy-web/duplicacy_web_linux_x64_1.5.3
https://acrosync.com/duplicacy-web/duplicacy_web_linux_arm64_1.5.3
https://acrosync.com/duplicacy-web/duplicacy_web_linux_arm_1.5.3
https://acrosync.com/duplicacy-web/duplicacy_web_freebsd_x64_1.5.3
Changes:
Restore can now continue to run in the background after the Restore page is closed
Pass storage credentials to the CLI in keyring/keychain if
safe_credentialsis set totrueinsettings.json[1] -
In file/directory selection dialogs, directories can now be expanded or collapsed with double-clicks
Fixed an initialization failure bug when running multiple jobs in parallel
Fixed a bug that causes schedules to run repeatedly between 1am to 2am on the starting day of daylight saving time [2]
Fix a bug that causes a trial license to become invalid after a docker restart
[1] By default storage credentials needed by the CLI are passed as environment variables. If you create a new key in settings.json named safe_credentials and set it to true, then storage credentials will be saved in keyring/keychain which is visible to the CLI.
[2] You’ll be affected by this bug if you have a schedule to be run between 2am (inclusive) and 3am on this coming March 13th. If you don’t want to upgrade, a workaround is to temporarily change the run time of the schedule to before 2am or after 3am.
