Hello,
There seems to be a problem with my OneDrive setup.
I can’t see anywhere where I can check the settings.
Can anyone help here? Thank you very much.
Hello,
What do you mean by check the settings exactly? What are you trying to do?
The stats in the screenshot is updated every time you run a check, so visit the Schedule tab and find the check job and run it.
I mean the settings for my OneDrive.
When I setup a new OneDrive storage I’ve got these options (see screenshot).
Okay but what are you trying to do? Are the backups working?
Duplicacy doesn’t let you see or edit those settings (party because things like the token file can’t be easily discovered), so if you need to change them you’ll need to delete the storage and re-add it using the same storage name. You won’t lose data doing that.
Thanks for your quick help.
I recreated it and it’s working again.
Apparently, the odb_token.file had expired.
I still find it strange that you can’t edit an existing entry, though.
The token gets renewed automatically and updated in the same file. Was the token file on writable by duplicacy user filesystem?
There is nothing to edit really. It’s a path to token. Deleting and adding again achieves the same effect. But you shall never need to do that in the first place
I can’t say for sure.
I set up the storage again and got a message saying “Token expired.”
I then created a new one and it worked straight away.
Both files are in the same folder.
Initially it will work even if duplicacy does not have write access to the token.
How are you running? Natively? In the container? What is the host os? Where is that folder with tokens located? What user account is duplicacy confined to run as?
Thanks for your support. Everything is working again now that I’ve added it again.
Regarding your questions: I’m using an Unraid server here and Duplicacy is running in a docker.
