I’m experimenting and so (using the WebUI) far i haven’t had a failed backup. But i’ve noticed the email notifications i receive don’t give me RC=0 or similar. Does it only appear if there’s something other than 0?
I tried to get it to fail (to see how the email differed) by moving out a 1.2gb file during the backup - but it seemed to chug through it. Indeed, i was able to restore it.
I was hoping to use return codes to file the email with rules - if it returned 0 i’d send it straight to the bin, if not - i’d see it and check. Is there a command or global option to see this?
Thanks.
