I am new to duplicacy and have chosen storj as my storage backend.
I have seen Here is an article I wrote for using the CLI to backup to Storj Cloud (beta, re-writing sections) which says that you don’t need to use duplicacy init -e when backing up to storj as this would effectively be using two levels of encryption.
I would like to make sure of my understanding here: when backing up to storj via duplicacy, am I correct that duplicacy will encrypt the data at the client side before sending it, so it would never leave your local machine unencrypted? I think this would need to be the case but just wanted to check.
Thanks for any help.
