is it possible to set the options -erasure-coding, -pref-dir, -zstd-level when using the add command?
I do not see them listed Add command details
I have an already inited storage, and would like to add a new one for copy.
EDIT: If i’m not wrong, erasure coding is copied from the source storage, and the same should be for zstd level. -pref-dir should not be used, -repository is the way to go. Correct?
What is not clear is, snapshot ids should be the same between the 2 storages?
Thanks
