I added a test sftp backup target with RSA encryption.
When testing a restore from the GUI, I get the following output:
exit status 101
Exit code: 101
Clicking View log shows:
2026-11-28 11:01:00.316 INFO REPOSITORY_SET Repository set to /Users/kevin/code/private-infra/local/restore-test
2026-11-28 11:01:00.316 INFO STORAGE_SET Storage set to sftp://kevin@mynas//tank/backups/duplo-mac-testing
2026-11-28 11:01:00.665 INFO SNAPSHOT_FILTER Loaded 1 include/exclude pattern(s)
2026-11-28 11:01:00.851 INFO RESTORE_INPLACE Forcing in-place mode with a non-default preference path
2026-11-28 11:01:00.851 INFO RESTORE_INDEXING Indexing /Users/kevin/code/private-infra/local/restore-test
2026-11-28 11:01:00.851 INFO SNAPSHOT_FILTER Parsing filter file /Users/kevin/.duplicacy-web/repositories/localhost/restore/.duplicacy/filters
2026-11-28 11:01:00.852 INFO SNAPSHOT_FILTER Loaded 0 include/exclude pattern(s)
2026-11-28 11:01:00.890 INFO RESTORE_START Restoring /Users/kevin/code/private-infra/local/restore-test to revision 2
I put the following in options: -key /Users/kevin/code/private-infra/local/private.pem -key-passphrase PASSWORDHERE. The password doesn’t have any whitespace in it.
Potentially related? How to use RSA Key from CLI encrypted backups with Web GUI Restore
