So, here we go. It didn’t take very long until things started piling up. I’ll give you the last “ordinary” log and then the one five minutes later and another five minutes later (to stay within the max character limit per post I’m cutting out repetitive lines):
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
duplicacy 28590 root cwd DIR 0,50 60 16 /tmp/.duplicacy-web/repositories/localhost/all
duplicacy 28590 root rtd DIR 8,1 4096 2 /
duplicacy 28590 root txt REG 8,1 31740199 13369359 /.duplicacy-web/bin/duplicacy_linux_x64_2.6.1
duplicacy 28590 root 0r CHR 1,3 0t0 6 /dev/null
duplicacy 28590 root 1w FIFO 0,13 0t0 104332902 pipe
duplicacy 28590 root 2w CHR 1,3 0t0 6 /dev/null
duplicacy 28590 root 3u sock 0,9 0t0 104332951 protocol: TCP
duplicacy 28590 root 4u a_inode 0,14 0 11185 [eventpoll]
duplicacy 28590 root 5u sock 0,9 0t0 104333609 protocol: TCP
duplicacy 28590 root 6u IPv4 104856773 0t0 TCP server.lan:43182->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 6u IPv4 104880962 0t0 TCP server.lan:50474->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 7u IPv4 104880999 0t0 TCP server.lan:50526->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 8u IPv4 104881032 0t0 TCP server.lan:50532->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 9u IPv4 104881785 0t0 TCP server.lan:50550->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 10u IPv4 104881082 0t0 TCP server.lan:50576->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 11u IPv4 104881116 0t0 TCP server.lan:50634->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 12u IPv4 104881146 0t0 TCP server.lan:50708->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 13u IPv4 104883139 0t0 TCP server.lan:51406->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 14u IPv4 104885905 0t0 TCP server.lan:51414->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 15u IPv4 104883169 0t0 TCP server.lan:51450->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 16u IPv4 104885917 0t0 TCP server.lan:51500->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 17u IPv4 104885930 0t0 TCP server.lan:51540->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 18u IPv4 104886288 0t0 TCP server.lan:51584->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 19u IPv4 104885975 0t0 TCP server.lan:51588->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 20u IPv4 104885987 0t0 TCP server.lan:51590->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 21u IPv4 104885999 0t0 TCP server.lan:51618->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 22u IPv4 104886322 0t0 TCP server.lan:51676->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 23u IPv4 104886354 0t0 TCP server.lan:51698->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 24u IPv4 104886450 0t0 TCP server.lan:51748->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 25u IPv4 104886115 0t0 TCP server.lan:51776->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 26u IPv4 104886505 0t0 TCP server.lan:51794->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 27u IPv4 104886178 0t0 TCP server.lan:51864->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 28u IPv4 104886515 0t0 TCP server.lan:51880->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 29u IPv4 104886209 0t0 TCP server.lan:51930->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 30u IPv4 104888482 0t0 TCP server.lan:51958->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 31u IPv4 104888490 0t0 TCP server.lan:51962->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 32u IPv4 104888495 0t0 TCP server.lan:51980->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 33u IPv4 104888528 0t0 TCP server.lan:52042->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 34u IPv4 104888543 0t0 TCP server.lan:52058->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 35u IPv4 104889426 0t0 TCP server.lan:52072->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 36u IPv4 104889429 0t0 TCP server.lan:52110->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 37u IPv4 104888612 0t0 TCP server.lan:52132->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 38u IPv4 104889468 0t0 TCP server.lan:52144->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 39u IPv4 104888620 0t0 TCP server.lan:52146->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 40u IPv4 104888637 0t0 TCP server.lan:52208->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 41u IPv4 104889564 0t0 TCP server.lan:52240->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 42u IPv4 104889570 0t0 TCP server.lan:52248->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 43u IPv4 104888691 0t0 TCP server.lan:52296->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 44u IPv4 104888693 0t0 TCP server.lan:52300->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 45u IPv4 104889587 0t0 TCP server.lan:52326->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 46u IPv4 104888708 0t0 TCP server.lan:52328->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 47u IPv4 104888728 0t0 TCP server.lan:52378->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 48u IPv4 104889017 0t0 TCP server.lan:52404->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 49u IPv4 104890227 0t0 TCP server.lan:52454->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 50u IPv4 104889104 0t0 TCP server.lan:52482->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 51u IPv4 104889114 0t0 TCP server.lan:52502->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 52u IPv4 104890250 0t0 TCP server.lan:52510->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 53u IPv4 104889128 0t0 TCP server.lan:52556->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 54u IPv4 104890305 0t0 TCP server.lan:52576->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 55u IPv4 104889175 0t0 TCP server.lan:52594->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 56u IPv4 104890324 0t0 TCP server.lan:52646->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 57u IPv4 104889207 0t0 TCP server.lan:52666->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 58u IPv4 104890336 0t0 TCP server.lan:52688->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 59u IPv4 104891458 0t0 TCP server.lan:52844->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 6u sock 0,9 0t0 104880962 protocol: TCP
duplicacy 28590 root 7u sock 0,9 0t0 104880999 protocol: TCP
duplicacy 28590 root 8u sock 0,9 0t0 104881032 protocol: TCP
duplicacy 28590 root 9u sock 0,9 0t0 104881785 protocol: TCP
duplicacy 28590 root 10u sock 0,9 0t0 104881082 protocol: TCP
duplicacy 28590 root 11u sock 0,9 0t0 104881116 protocol: TCP
duplicacy 28590 root 12u sock 0,9 0t0 104881146 protocol: TCP
duplicacy 28590 root 13u sock 0,9 0t0 104883139 protocol: TCP
duplicacy 28590 root 14u sock 0,9 0t0 104885905 protocol: TCP
duplicacy 28590 root 15u sock 0,9 0t0 104883169 protocol: TCP
duplicacy 28590 root 16u sock 0,9 0t0 104885917 protocol: TCP
duplicacy 28590 root 17u sock 0,9 0t0 104885930 protocol: TCP
duplicacy 28590 root 18u sock 0,9 0t0 104886288 protocol: TCP
duplicacy 28590 root 19u sock 0,9 0t0 104885975 protocol: TCP
duplicacy 28590 root 20u sock 0,9 0t0 104885987 protocol: TCP
duplicacy 28590 root 21u sock 0,9 0t0 104885999 protocol: TCP
duplicacy 28590 root 22u sock 0,9 0t0 104886322 protocol: TCP
duplicacy 28590 root 23u sock 0,9 0t0 104886354 protocol: TCP
duplicacy 28590 root 24u sock 0,9 0t0 104886450 protocol: TCP
duplicacy 28590 root 25u sock 0,9 0t0 104886115 protocol: TCP
duplicacy 28590 root 26u sock 0,9 0t0 104886505 protocol: TCP
duplicacy 28590 root 27u sock 0,9 0t0 104886178 protocol: TCP
duplicacy 28590 root 28u sock 0,9 0t0 104886515 protocol: TCP
duplicacy 28590 root 29u sock 0,9 0t0 104886209 protocol: TCP
duplicacy 28590 root 30u sock 0,9 0t0 104888482 protocol: TCP
duplicacy 28590 root 31u sock 0,9 0t0 104888490 protocol: TCP
duplicacy 28590 root 32u sock 0,9 0t0 104888495 protocol: TCP
duplicacy 28590 root 33u sock 0,9 0t0 104888528 protocol: TCP
duplicacy 28590 root 34u sock 0,9 0t0 104888543 protocol: TCP
duplicacy 28590 root 35u sock 0,9 0t0 104889426 protocol: TCP
duplicacy 28590 root 36u sock 0,9 0t0 104889429 protocol: TCP
duplicacy 28590 root 37u sock 0,9 0t0 104888612 protocol: TCP
duplicacy 28590 root 38u sock 0,9 0t0 104889468 protocol: TCP
duplicacy 28590 root 39u sock 0,9 0t0 104888620 protocol: TCP
[160 lines cut]
duplicacy 28590 root 200u sock 0,9 0t0 104910169 protocol: TCP
duplicacy 28590 root 201u sock 0,9 0t0 104910884 protocol: TCP
duplicacy 28590 root 202u sock 0,9 0t0 104910197 protocol: TCP
duplicacy 28590 root 203u sock 0,9 0t0 104910917 protocol: TCP
duplicacy 28590 root 204u sock 0,9 0t0 104910939 protocol: TCP
duplicacy 28590 root 205u sock 0,9 0t0 104910947 protocol: TCP
duplicacy 28590 root 206u sock 0,9 0t0 104911036 protocol: TCP
duplicacy 28590 root 207u sock 0,9 0t0 104911100 protocol: TCP
duplicacy 28590 root 208u sock 0,9 0t0 104910633 protocol: TCP
duplicacy 28590 root 209u sock 0,9 0t0 104911733 protocol: TCP
duplicacy 28590 root 210u sock 0,9 0t0 104910656 protocol: TCP
duplicacy 28590 root 211u sock 0,9 0t0 104910670 protocol: TCP
duplicacy 28590 root 212u sock 0,9 0t0 104911782 protocol: TCP
duplicacy 28590 root 213u sock 0,9 0t0 104910686 protocol: TCP
duplicacy 28590 root 214u sock 0,9 0t0 104911792 protocol: TCP
duplicacy 28590 root 215u sock 0,9 0t0 104911803 protocol: TCP
duplicacy 28590 root 216u sock 0,9 0t0 104911878 protocol: TCP
duplicacy 28590 root 217u sock 0,9 0t0 104911852 protocol: TCP
duplicacy 28590 root 218u sock 0,9 0t0 104912913 protocol: TCP
duplicacy 28590 root 219u IPv4 104912052 0t0 TCP server.lan:59000->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 220u sock 0,9 0t0 104912060 protocol: TCP
duplicacy 28590 root 221u sock 0,9 0t0 104912068 protocol: TCP
duplicacy 28590 root 222u sock 0,9 0t0 104912071 protocol: TCP
duplicacy 28590 root 223u sock 0,9 0t0 104913009 protocol: TCP
duplicacy 28590 root 224u IPv4 104912126 0t0 TCP server.lan:59142->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 225u sock 0,9 0t0 104913028 protocol: TCP
duplicacy 28590 root 226u sock 0,9 0t0 104915012 protocol: TCP
duplicacy 28590 root 227u IPv4 104915017 0t0 TCP server.lan:59180->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 228u sock 0,9 0t0 104915033 protocol: TCP
duplicacy 28590 root 229u sock 0,9 0t0 104913052 protocol: TCP
duplicacy 28590 root 230u IPv4 104915061 0t0 TCP server.lan:59258->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 231u sock 0,9 0t0 104913068 protocol: TCP
duplicacy 28590 root 232u sock 0,9 0t0 104913161 protocol: TCP
duplicacy 28590 root 233u IPv4 104915177 0t0 TCP server.lan:59340->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 234u IPv4 104913181 0t0 TCP server.lan:59350->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 235u IPv4 104913190 0t0 TCP server.lan:59384->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 236u IPv4 104913199 0t0 TCP server.lan:59400->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 237u sock 0,9 0t0 104915237 protocol: TCP
duplicacy 28590 root 238u IPv4 104915246 0t0 TCP server.lan:59482->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 239u sock 0,9 0t0 104915266 protocol: TCP
duplicacy 28590 root 240u sock 0,9 0t0 104915277 protocol: TCP
duplicacy 28590 root 241u sock 0,9 0t0 104915312 protocol: TCP
duplicacy 28590 root 242u sock 0,9 0t0 104915323 protocol: TCP
duplicacy 28590 root 243u IPv4 104915341 0t0 TCP server.lan:59570->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 244u IPv4 104915363 0t0 TCP server.lan:59628->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 245u sock 0,9 0t0 104915401 protocol: TCP
duplicacy 28590 root 246u IPv4 104915423 0t0 TCP server.lan:59660->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 247u IPv4 104915821 0t0 TCP server.lan:59674->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 248u IPv4 104915832 0t0 TCP server.lan:59690->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 249u sock 0,9 0t0 104916103 protocol: TCP
duplicacy 28590 root 250u IPv4 104916112 0t0 TCP server.lan:59780->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 251u sock 0,9 0t0 104916127 protocol: TCP
duplicacy 28590 root 252u IPv4 104915883 0t0 TCP server.lan:59826->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 253u IPv4 104915886 0t0 TCP server.lan:59840->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 254u IPv4 104916175 0t0 TCP server.lan:59858->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 255u IPv4 104915907 0t0 TCP server.lan:59878->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 256u IPv4 104915932 0t0 TCP server.lan:59920->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 257u IPv4 104915967 0t0 TCP server.lan:59950->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 258u IPv4 104916278 0t0 TCP server.lan:59958->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 259u IPv4 104916285 0t0 TCP server.lan:59984->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 260u IPv4 104916293 0t0 TCP server.lan:60000->api13.pcloud.com:https (CLOSE_WAIT)
[50 lines cut]
duplicacy 28590 root 311u IPv4 104919469 0t0 TCP server.lan:33076->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 312u IPv4 104919476 0t0 TCP server.lan:33086->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 313u IPv4 104921699 0t0 TCP server.lan:33124->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 314u IPv4 104919518 0t0 TCP server.lan:33132->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 315u IPv4 104919660 0t0 TCP server.lan:33280->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 316u IPv4 104919667 0t0 TCP server.lan:33298->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 317u IPv4 104921938 0t0 TCP server.lan:33338->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 318u IPv4 104923150 0t0 TCP server.lan:33540->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 319u IPv4 104922302 0t0 TCP server.lan:33590->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 320u IPv4 104923194 0t0 TCP server.lan:33596->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 321u IPv4 104923293 0t0 TCP server.lan:33688->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 322u IPv4 104923319 0t0 TCP server.lan:33744->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 323u IPv4 104923322 0t0 TCP server.lan:33748->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 324u IPv4 104923354 0t0 TCP server.lan:33760->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 325u IPv4 104922495 0t0 TCP server.lan:33778->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 326u IPv4 104923401 0t0 TCP server.lan:33806->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 327u IPv4 104922516 0t0 TCP server.lan:33832->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 328u IPv4 104922530 0t0 TCP server.lan:33852->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 329u IPv4 104923445 0t0 TCP server.lan:33908->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 330u IPv4 104923497 0t0 TCP server.lan:33912->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 331u IPv4 104922622 0t0 TCP server.lan:33914->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 332u IPv4 104922632 0t0 TCP server.lan:33932->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 333u IPv4 104923515 0t0 TCP server.lan:33966->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 334u IPv4 104923521 0t0 TCP server.lan:33992->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 335u IPv4 104923527 0t0 TCP server.lan:34002->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 336u IPv4 104922744 0t0 TCP server.lan:34068->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 337u IPv4 104923548 0t0 TCP server.lan:34078->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 338u IPv4 104923554 0t0 TCP server.lan:34080->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 339u IPv4 104922767 0t0 TCP server.lan:34092->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 340u IPv4 104923579 0t0 TCP server.lan:34112->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 341u IPv4 104922813 0t0 TCP server.lan:34142->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 342u IPv4 104922822 0t0 TCP server.lan:34162->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 343u IPv4 104922827 0t0 TCP server.lan:34216->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 344u IPv4 104923708 0t0 TCP server.lan:34240->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 345u IPv4 104922899 0t0 TCP server.lan:34242->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 346u IPv4 104922917 0t0 TCP server.lan:34252->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 347u IPv4 104924057 0t0 TCP server.lan:34262->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 348u IPv4 104924216 0t0 TCP server.lan:34294->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 349u IPv4 104924093 0t0 TCP server.lan:34322->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 350u IPv4 104924099 0t0 TCP server.lan:34364->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 351u IPv4 104924249 0t0 TCP server.lan:34394->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 352u IPv4 104924118 0t0 TCP server.lan:34404->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 353u IPv4 104924262 0t0 TCP server.lan:34412->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 354u IPv4 104924129 0t0 TCP server.lan:34426->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 355u IPv4 104924276 0t0 TCP server.lan:34444->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 356u IPv4 104924323 0t0 TCP server.lan:34494->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 357u IPv4 104925262 0t0 TCP server.lan:34540->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 358u IPv4 104925325 0t0 TCP server.lan:34564->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 359u IPv4 104925330 0t0 TCP server.lan:34574->api13.pcloud.com:https (ESTABLISHED)
duplicacy 28590 root 360u IPv4 104925338 0t0 TCP server.lan:34580->api13.pcloud.com:https (CLOSE_WAIT)
duplicacy 28590 root 361u IPv4 104925343 0t0 TCP server.lan:34596->api13.pcloud.com:https (ESTABLISHED)
The number of open files then increases every five minutes. The last log before the command failed has over 1000 entries.
Does “CLOSE_WAIT” mean that @saspus was right about the orphaned connections?
