Hi folks,
I’m getting permissions error that wasn’t there before and not sure how to resolve. I’ve looked through the forum and online and cannot find the solution, if you have a moment to point me in the right direction to help fix, would be most appreciated:
Back up /mnt/user/Ciarans Files@localhost to storage BackupDrive, status: Failed, log file: backup-20240523-123626.log
Running backup command from /cache/localhost/0 to back up /mnt/user/Ciarans Files
Options: [-log backup -storage BackupDrive -threads 1 -stats]
2024-05-23 12:36:26.766 INFO REPOSITORY_SET Repository set to /mnt/user/Ciarans Files
2024-05-23 12:36:26.767 INFO STORAGE_SET Storage set to /mnt/disks/5QH2UBVF
2024-05-23 12:36:26.767 ERROR STORAGE_CREATE Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied
Back up /mnt/user/Lindsays Files@localhost to storage BackupDrive, status: Failed, log file: backup-20240523-123625.log
Running backup command from /cache/localhost/1 to back up /mnt/user/Lindsays Files
2024-05-23 12:36:25.768 INFO REPOSITORY_SET Repository set to /mnt/user/Lindsays Files
2024-05-23 12:36:25.768 INFO STORAGE_SET Storage set to /mnt/disks/5QH2UBVF
2024-05-23 12:36:25.768 ERROR STORAGE_CREATE Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied
Back up /mnt/user/appdata@localhost to storage BackupDrive, status: Failed, log file: backup-20240523-123624.log
Running backup command from /cache/localhost/4 to back up /mnt/user/appdata
2024-05-23 12:36:24.762 INFO REPOSITORY_SET Repository set to /mnt/user/appdata
2024-05-23 12:36:24.762 INFO STORAGE_SET Storage set to /mnt/disks/5QH2UBVF
2024-05-23 12:36:24.762 ERROR STORAGE_CREATE Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied
Back up /mnt/user/pictures@localhost to storage BackupDrive, status: Failed, log file: backup-20240523-123627.log
Running backup command from /cache/localhost/6 to back up /mnt/user/pictures
2024-05-23 12:36:27.768 INFO REPOSITORY_SET Repository set to /mnt/user/pictures
2024-05-23 12:36:27.768 INFO STORAGE_SET Storage set to /mnt/disks/5QH2UBVF
2024-05-23 12:36:27.769 ERROR STORAGE_CREATE Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied
Back up /Users/Games@localhost to storage BackupDrive, status: Failed, log file: backup-20240523-123623.log
Running backup command from /cache/localhost/8 to back up /Users/Games
2024-05-23 12:36:23.754 INFO REPOSITORY_SET Repository set to /Users/Games
2024-05-23 12:36:23.755 INFO STORAGE_SET Storage set to /mnt/disks/5QH2UBVF
2024-05-23 12:36:23.755 ERROR STORAGE_CREATE Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied
Back up /Users/music audio@localhost to storage BackupDrive, status: Failed, log file: backup-20240523-123622.log
Running backup command from /cache/localhost/10 to back up /Users/music audio
2024-05-23 12:36:22.763 INFO REPOSITORY_SET Repository set to /Users/music audio
2024-05-23 12:36:22.763 INFO STORAGE_SET Storage set to /mnt/disks/5QH2UBVF
2024-05-23 12:36:22.764 ERROR STORAGE_CREATE Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied Failed to load the file storage at /mnt/disks/5QH2UBVF: mkdir /mnt/disks: permission denied
