Hi All,
New user here. I have setup and tested using Storj as destination with no issues.
However, now backups are actually running, I keep getting errors similar to these, on both new and incremental backups, at random times at which point the backup stops and fails (some values redacted);
2023-03-04 12:41:43.802 ERROR UPLOAD_CHUNK Failed to upload the chunk xxx: RequestError: send request failed
caused by: Put "https://duplicacy.gateway.storjshare.io/chunks/xx/xxx": read tcp 9.9.9.9:1234->185.244.226.3:443: read: connection reset by peer
Is it possible to find cause?
Is there a way to force retry when this happens?
Thanks in advance
