Hello,
While backing up my data to Backblaze B2 I encountered several error messages (not many, around 50 errors for 40GB of data).
2017-09-20 05:02:03.586 INFO BACKBLAZE_UPLOAD URL request 'https://pod-000-1728-07.backblaze.com/b2api/v1/b2_upload_file/f7da76fd6add26c35ded0e1a/c021_v0001038_t0321' returned status code 408
and
URL request 'https://pod-000-1304-04.backblaze.com/b2api/v1/b2_upload_file/f7da77ed6ade27c35ded2c1b/c001_v0001090_t8010' returned status code 503
My questions are:
- Does Duplicacy resend the chunk after it encounters an error?
- How can I make sure that the backup is correct? The duplicacy check command only verifies that the chunks exist and duplicacy check -files requires a huge download which I’d like to avoid. Is there an option to verify only a single file or a small group of files?
Thank again.
