I’m finally updating from the GUI app to the Web-GUI.
My home network with two servers, a PC and two roving mac laptops has been happily running on the old GUI-app. Luckily I haven’t had any failures that required me to pull from a backup, but I suspect it’s all been working fine.
But various other (NON-Duplicacy) issues have told me it’s time to upgrade.
Frankly, for a person who just “lets it run” for a couple years after it was setup there is a learning curve to remember what is going on. That is kind of a complement, I basically ignored Duplicacy for a long time!
On the other hand, I do think it is a “pro-level” tool. I’m basically an old hardware engineer, so I can figure this stuff out. but it takes me some work. It’s probably really easy for a SW or IT type, but that’s not me. I only know enough to be dangerous. If you have some good software / networking background, I suspect this is very easy and great to use!
I do like the web interface. It DOES seem better and much more informative that the old app-GUI.
So…
THANK YOU!
Good work guys.
