Hi all,
I’m experiencing an issue similar to this.
My setup is as follows:
- Storage: local NAS, accessed over SMB.
- Two computers, both running Duplicacy Web UI. One is running as a local user, the other is running as a system service.
- Both computers have a modest amount of files that are identical (e.g. family photos) and a variety of unique files (different documents, etc.).
- Both computers are backing up to the same storage.
- Each computer has a different backup ID.
- One computer is set run backups hourly with check, backup, prune, check. The second computer is set to just do a one-time, manual backup. The prune options are
-keep 0:1800 -keep 365:365 -keep 30:30 -keep 7:14 -keep 1:1 -a. - I had one computer complete a full, initial backup alone and then had the second computer start its initial backup.
The two computers both backed up to the storage as expected and reported their success in the logs. For example, the first computer (serenity) reported the following:
2024-12-12 16:43:36.959 INFO BACKUP_END Backup for C:\Users\<name> at revision 24 completed
2024-12-12 16:43:36.960 INFO BACKUP_STATS Files: 127731 total, 435,111M bytes; 2 new, 19K bytes
2024-12-12 16:43:36.960 INFO BACKUP_STATS File chunks: 12531 total, 435,918M bytes; 1 new, 19K bytes, 3K bytes uploaded
2024-12-12 16:43:36.960 INFO BACKUP_STATS Metadata chunks: 17 total, 22,186K bytes; 4 new, 5,122K bytes, 2,362K bytes uploaded
2024-12-12 16:43:36.960 INFO BACKUP_STATS All chunks: 12548 total, 435,940M bytes; 5 new, 5,142K bytes, 2,366K bytes uploaded
2024-12-12 16:43:36.960 INFO BACKUP_STATS Total running time: 00:00:29
When the second computer (inara) was in the middle of uploading, the first computer ran a check which generated the following output indicating everything is in order:
2024-12-12 23:07:02.002 INFO STORAGE_SET Storage set to smb://heypete@diskstation.internal.heypete.com/Backups/duplicacy
2024-12-12 23:07:04.310 INFO SNAPSHOT_CHECK Listing all chunks
Creating directory snapshots/inara-pete/
Creating directory snapshots/serenity-pete-homedir/
2024-12-12 23:07:11.879 INFO SNAPSHOT_CHECK 2 snapshots and 27 revisions
2024-12-12 23:07:11.880 INFO SNAPSHOT_CHECK Total chunk size is 576,047M in 15477 chunks
2024-12-12 23:07:11.915 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 1 exist
2024-12-12 23:07:11.936 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 5 exist
2024-12-12 23:07:11.959 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 6 exist
2024-12-12 23:07:11.981 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 7 exist
2024-12-12 23:07:12.003 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 8 exist
2024-12-12 23:07:12.026 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 9 exist
2024-12-12 23:07:12.049 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 10 exist
2024-12-12 23:07:12.069 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 11 exist
2024-12-12 23:07:12.087 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 12 exist
2024-12-12 23:07:12.106 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 13 exist
2024-12-12 23:07:12.125 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 14 exist
2024-12-12 23:07:12.143 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 15 exist
2024-12-12 23:07:12.162 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 16 exist
2024-12-12 23:07:12.182 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 17 exist
2024-12-12 23:07:12.207 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 18 exist
2024-12-12 23:07:12.225 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 19 exist
2024-12-12 23:07:12.245 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 20 exist
2024-12-12 23:07:12.264 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 21 exist
2024-12-12 23:07:12.282 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 22 exist
2024-12-12 23:07:12.301 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 23 exist
2024-12-12 23:07:12.324 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 24 exist
2024-12-12 23:07:12.342 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 25 exist
2024-12-12 23:07:12.362 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 26 exist
2024-12-12 23:07:12.380 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 27 exist
2024-12-12 23:07:12.399 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 28 exist
2024-12-12 23:07:12.417 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 29 exist
2024-12-12 23:07:12.437 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 30 exist
2024-12-12 23:07:13.395 INFO SNAPSHOT_CHECK
inara-pete | all | | | | 0 | 0 | 0 | 0 | | |
serenity-pete-homedir | 1 | @ 2024-12-11 17:12 -hash -vss | 129188 | 435,313M | 10937 | 406,772M | 4 | 1,858K | 10937 | 406,772M |
serenity-pete-homedir | 5 | @ 2024-12-12 00:07 -vss | 129210 | 435,317M | 10942 | 406,772M | 5 | 1,859K | 9 | 2,391K |
serenity-pete-homedir | 6 | @ 2024-12-12 01:07 -vss | 129214 | 435,317M | 10941 | 406,776M | 5 | 1,986K | 13 | 10,789K |
serenity-pete-homedir | 7 | @ 2024-12-12 02:07 -vss | 129218 | 435,317M | 10942 | 406,776M | 5 | 1,987K | 6 | 2,037K |
serenity-pete-homedir | 8 | @ 2024-12-12 03:07 -vss | 129222 | 435,317M | 10942 | 406,776M | 4 | 1,986K | 5 | 2,035K |
serenity-pete-homedir | 9 | @ 2024-12-12 04:07 -vss | 129226 | 435,317M | 10944 | 406,776M | 5 | 1,985K | 6 | 2,034K |
serenity-pete-homedir | 10 | @ 2024-12-12 05:07 -vss | 129230 | 435,317M | 10944 | 406,776M | 4 | 1,986K | 5 | 2,035K |
serenity-pete-homedir | 11 | @ 2024-12-12 06:07 -vss | 129234 | 435,317M | 10945 | 406,776M | 4 | 1,986K | 5 | 2,035K |
serenity-pete-homedir | 12 | @ 2024-12-12 07:07 -vss | 129238 | 435,317M | 10946 | 406,776M | 4 | 1,987K | 5 | 2,036K |
serenity-pete-homedir | 13 | @ 2024-12-12 07:49 -vss | 129242 | 435,317M | 10947 | 406,776M | 4 | 1,987K | 5 | 2,036K |
serenity-pete-homedir | 14 | @ 2024-12-12 08:07 -vss | 129246 | 435,317M | 10948 | 406,776M | 4 | 1,987K | 5 | 2,164K |
serenity-pete-homedir | 15 | @ 2024-12-12 08:53 -vss | 129250 | 435,318M | 10950 | 406,777M | 5 | 1,991K | 6 | 2,043K |
serenity-pete-homedir | 16 | @ 2024-12-12 09:07 -vss | 129251 | 435,318M | 10950 | 406,777M | 4 | 1,989K | 5 | 2,042K |
serenity-pete-homedir | 17 | @ 2024-12-12 10:07 -vss | 129256 | 435,318M | 10951 | 406,777M | 5 | 2,467K | 6 | 2,528K |
serenity-pete-homedir | 18 | @ 2024-12-12 11:07 -vss | 129260 | 435,318M | 10952 | 406,777M | 6 | 2,758K | 7 | 2,811K |
serenity-pete-homedir | 19 | @ 2024-12-12 12:07 -vss | 129264 | 435,318M | 10952 | 406,777M | 4 | 2,466K | 5 | 2,520K |
serenity-pete-homedir | 20 | @ 2024-12-12 13:07 -vss | 129268 | 435,318M | 10953 | 406,777M | 4 | 2,467K | 5 | 2,522K |
serenity-pete-homedir | 21 | @ 2024-12-12 14:07 -vss | 129272 | 435,318M | 10954 | 406,777M | 4 | 2,466K | 5 | 2,520K |
serenity-pete-homedir | 22 | @ 2024-12-12 15:07 -vss | 129276 | 435,318M | 10956 | 406,777M | 5 | 2,466K | 6 | 2,521K |
serenity-pete-homedir | 23 | @ 2024-12-12 16:07 -vss | 129280 | 435,318M | 10956 | 406,777M | 5 | 2,521K | 5 | 2,521K |
serenity-pete-homedir | 24 | @ 2024-12-12 16:43 -vss | 127731 | 435,111M | 10933 | 406,754M | 4 | 2,362K | 5 | 2,366K |
serenity-pete-homedir | 25 | @ 2024-12-12 17:07 -vss | 127738 | 435,111M | 10934 | 406,754M | 4 | 2,360K | 5 | 2,368K |
serenity-pete-homedir | 26 | @ 2024-12-12 18:07 -vss | 127743 | 435,111M | 10935 | 406,754M | 4 | 2,361K | 5 | 2,369K |
serenity-pete-homedir | 27 | @ 2024-12-12 19:07 -vss | 127749 | 435,111M | 10936 | 406,754M | 4 | 2,361K | 5 | 2,371K |
serenity-pete-homedir | 28 | @ 2024-12-12 20:07 -vss | 127754 | 435,112M | 10937 | 406,754M | 4 | 2,361K | 5 | 2,371K |
serenity-pete-homedir | 29 | @ 2024-12-12 21:07 -vss | 127761 | 435,114M | 10938 | 406,757M | 4 | 2,362K | 5 | 5,726K |
serenity-pete-homedir | 30 | @ 2024-12-12 22:07 -vss | 127766 | 435,114M | 10939 | 406,757M | 5 | 2,372K | 5 | 2,372K |
serenity-pete-homedir | all | | | | 11086 | 406,841M | 11086 | 406,841M | | |
However, this morning, when the check on the first computer ran (after the second computer had finished its initial backup), it reported the following issues:
2024-12-13 00:07:08.885 INFO SNAPSHOT_CHECK 2 snapshots and 29 revisions
2024-12-13 00:07:08.885 INFO SNAPSHOT_CHECK Total chunk size is 604,564M in 16354 chunks
2024-12-13 00:07:08.909 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 1 exist
2024-12-13 00:07:08.930 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 5 exist
2024-12-13 00:07:08.949 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 6 exist
2024-12-13 00:07:08.968 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 7 exist
2024-12-13 00:07:08.986 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 8 exist
2024-12-13 00:07:09.007 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 9 exist
2024-12-13 00:07:09.026 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 10 exist
2024-12-13 00:07:09.044 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 11 exist
2024-12-13 00:07:09.064 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 12 exist
2024-12-13 00:07:09.084 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 13 exist
2024-12-13 00:07:09.102 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 14 exist
2024-12-13 00:07:09.121 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 15 exist
2024-12-13 00:07:09.139 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 16 exist
2024-12-13 00:07:09.160 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 17 exist
2024-12-13 00:07:09.179 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 18 exist
2024-12-13 00:07:09.199 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 19 exist
2024-12-13 00:07:09.219 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 20 exist
2024-12-13 00:07:09.237 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 21 exist
2024-12-13 00:07:09.257 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 22 exist
2024-12-13 00:07:09.274 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 23 exist
2024-12-13 00:07:09.293 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 24 exist
2024-12-13 00:07:09.312 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 25 exist
2024-12-13 00:07:09.330 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 26 exist
2024-12-13 00:07:09.349 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 27 exist
2024-12-13 00:07:09.367 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 28 exist
2024-12-13 00:07:09.385 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 29 exist
2024-12-13 00:07:09.408 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 30 exist
2024-12-13 00:07:09.428 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 31 exist
2024-12-13 00:07:09.521 WARN SNAPSHOT_VALIDATE Chunk 65b5e3afdee209b7edb7779e011cc63aba1934bb6f6cb8ca8c2db5e950833a37 referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.523 WARN SNAPSHOT_VALIDATE Chunk 74a60ed591be3bf33b44920b596bcafaec773f6692770c48d0997b227dc5adeb referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.524 WARN SNAPSHOT_VALIDATE Chunk 6d6f8a69f1b5a04a883a090c3dc54e1f0cda2bb41fde3bc06dcc87d8d6c2e700 referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.528 WARN SNAPSHOT_VALIDATE Chunk 689de1b39f9909e912050998dc8f0a6dc5463fd674ff35f1f3075a6cf60e124b referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.529 WARN SNAPSHOT_VALIDATE Chunk b23b829b9e50c3f7b43d0bd8a7fbbbf5d40a6dce208d2c43978fc3adae23dcc3 referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.531 WARN SNAPSHOT_VALIDATE Chunk 3fb7d0f4dc782cc6ee4706395743641d3739597678dd18ec430ef70123b7bbfd referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.532 WARN SNAPSHOT_VALIDATE Chunk f6a382c23da1f79f6c1304a59dea3f2de3f9ef8ad9bc0f6b8f71d7acc355b1e1 referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.547 WARN SNAPSHOT_VALIDATE Chunk e7634f5245d891182518dcc20a91cb12e4fd43544cff8198601614633018b53b referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.548 WARN SNAPSHOT_VALIDATE Chunk 77a70b4ff2f1b23927dc5897c48185c8d9bf9d21b0e113146190745f66fd7ee0 referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.550 WARN SNAPSHOT_VALIDATE Chunk df3ec9b2cbe07387decd46d0a9cf556e3362356c6cae2f488cb8854855e17a0d referenced by snapshot inara-pete at revision 1 does not exist
2024-12-13 00:07:09.550 WARN SNAPSHOT_CHECK Some chunks referenced by snapshot inara-pete at revision 1 are missing
2024-12-13 00:07:09.550 ERROR SNAPSHOT_CHECK Some chunks referenced by some snapshots do not exist in the storage
I deleted the .duplicacy-web\repositories\ directory on the first computer to delete the local cache and re-ran the check. It produced the following output indicating everything is in order:
2024-12-13 08:39:21.820 INFO SNAPSHOT_CHECK 2 snapshots and 12 revisions
2024-12-13 08:39:21.820 INFO SNAPSHOT_CHECK Total chunk size is 604,893M in 16292 chunks
2024-12-13 08:39:21.850 INFO SNAPSHOT_CHECK All chunks referenced by snapshot inara-pete at revision 1 exist
2024-12-13 08:39:21.874 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 1 exist
2024-12-13 08:39:21.896 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 5 exist
2024-12-13 08:39:21.918 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 32 exist
2024-12-13 08:39:21.940 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 33 exist
2024-12-13 08:39:21.963 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 34 exist
2024-12-13 08:39:21.985 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 35 exist
2024-12-13 08:39:22.006 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 36 exist
2024-12-13 08:39:22.025 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 37 exist
2024-12-13 08:39:22.042 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 38 exist
2024-12-13 08:39:22.061 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 39 exist
2024-12-13 08:39:22.080 INFO SNAPSHOT_CHECK All chunks referenced by snapshot serenity-pete-homedir at revision 40 exist
2024-12-13 08:39:22.495 INFO SNAPSHOT_CHECK
inara-pete | 1 | @ 2024-12-13 00:53 -hash | 139990 | 288,991M | 7679 | 288,457M | 5271 | 197,973M | 7679 | 288,457M |
inara-pete | all | | | | 7679 | 288,457M | 5271 | 197,973M | | |
serenity-pete-homedir | 5 | @ 2024-12-12 00:07 -vss | 129210 | 435,317M | 10942 | 406,772M | 9 | 2,391K | 9 | 2,391K |
serenity-pete-homedir | 32 | @ 2024-12-13 00:07 -vss | 127776 | 435,114M | 10941 | 406,757M | 4 | 2,363K | 22 | 14,660K |
serenity-pete-homedir | 33 | @ 2024-12-13 01:07 -vss | 127782 | 435,114M | 10942 | 406,757M | 4 | 2,363K | 5 | 2,374K |
serenity-pete-homedir | 34 | @ 2024-12-13 02:07 -vss | 127787 | 435,115M | 10943 | 406,757M | 4 | 2,364K | 5 | 2,380K |
serenity-pete-homedir | 35 | @ 2024-12-13 03:07 -vss | 127792 | 435,115M | 10944 | 406,757M | 4 | 2,364K | 5 | 2,374K |
serenity-pete-homedir | 36 | @ 2024-12-13 04:07 -vss | 127797 | 435,115M | 10945 | 406,757M | 4 | 2,365K | 5 | 2,375K |
serenity-pete-homedir | 37 | @ 2024-12-13 05:07 -vss | 127802 | 435,115M | 10947 | 406,757M | 6 | 2,657K | 7 | 2,666K |
serenity-pete-homedir | 38 | @ 2024-12-13 06:07 -vss | 127807 | 435,115M | 10947 | 406,757M | 4 | 2,366K | 5 | 2,376K |
serenity-pete-homedir | 39 | @ 2024-12-13 07:07 -vss | 127812 | 435,115M | 10948 | 406,757M | 4 | 2,366K | 6 | 2,673K |
serenity-pete-homedir | 40 | @ 2024-12-13 08:07 -vss | 127817 | 435,115M | 10949 | 406,757M | 5 | 2,377K | 5 | 2,377K |
serenity-pete-homedir | all | | | | 11011 | 406,807M | 8603 | 316,324M | | |
Clearly the chunks exist on the storage, but Duplicacy refuses to see them until one deletes the cache.
Is it possible to
- Have Duplicacy actually check the storage to confirm the existence or non-existence of a chunk if the check reveals a potential issue like a missing chunk? (In essence, keeping the cache in agreement with the actual state of the storage.)
- Have an option to force Duplicacy to check the existence or non-existence of chunks during a check? (Without needing to actually verify the contents of the chunk, like with
-chunksor-files, just the existence or non-existence of a chunk.)
Thank you.
-Pete
