Having setup my google drive in duplicacy-web I expected that the token would be stored away somewhere and so I deleted the downloaded gcd-token.json file. However duplicacy then says it can’t connect to my google drive.
2019-08-08 17:32:18.173 ERROR STORAGE_CREATE Failed to load the Google Drive storage at gcd://Backups/PCName: open C:/Users/Phil/Downloads/gcd-token.json: The system cannot find the file specified.
When I look in the duplicacy.json file though I find this entry (modified a bit for security)
"name": "PCName",
"url": "gcd://Backups/PCName",
"encrypted": true,
"credentials": {
"gcd_token": "dfd689..............10c45f",
"password": "c1aee...............32dda"
So it seems like it has something stored but isn’t being used.
So should it be using the stored copy or the file?
If its supposed to use the file then is there anyway to move it so I don’t have it in my downloads folder forever?
