It pruned 275 days ago: https://i.imgur.com/lswYu1d.png
and it says backup completed successfully, but now i checked the logs and it actually does nothing…the backup finishes in 2 seconds.
This is the whole log:
Running backup command from D:/Cache/localhost/0 to back up C:/Backup Symbolic Links
Options: [-log backup -storage Duplicacy -stats]
2020-11-13 17:33:03.293 INFO REPOSITORY_SET Repository set to C:/Backup Symbolic Links
2020-11-13 17:33:03.360 INFO STORAGE_SET Storage set to gcd://Duplicacy Backup
2020-11-13 17:33:07.382 INFO BACKUP_START Last backup at revision 4894 found
2020-11-13 17:33:07.382 INFO BACKUP_INDEXING Indexing C:\Backup Symbolic Links
2020-11-13 17:33:07.382 INFO SNAPSHOT_FILTER Parsing filter file \?\D:\Cache\localhost\0.duplicacy\filters
2020-11-13 17:33:07.382 INFO SNAPSHOT_FILTER Loaded 8 include/exclude pattern(s)
2020-11-13 17:33:08.825 INFO BACKUP_END Backup for C:\Backup Symbolic Links at revision 4895 completed
2020-11-13 17:33:08.825 INFO BACKUP_STATS Files: 3 total, 41K bytes; 0 new, 0 bytes
2020-11-13 17:33:08.825 INFO BACKUP_STATS File chunks: 2 total, 3,971K bytes; 0 new, 0 bytes, 0 bytes uploaded
2020-11-13 17:33:08.825 INFO BACKUP_STATS Metadata chunks: 3 total, 787 bytes; 0 new, 0 bytes, 0 bytes uploaded
2020-11-13 17:33:08.825 INFO BACKUP_STATS All chunks: 5 total, 3,971K bytes; 0 new, 0 bytes, 0 bytes uploaded
2020-11-13 17:33:08.825 INFO BACKUP_STATS Total running time: 00:00:02
As you can tell, im using a folder with symbolic links to backup. been doing that for multiple years already, to just find out it stopped working almost a year ago.
Any way i can let it function again with my current google cloud backup structure, as its multiple tb’s?
