Help! Settings are gone after upgrading version!
I upgraded to the latest duplicacy just now, and see all my settings vanished. Is there a way to get back settings and folders set to backup?
If you’re upgrading from a pre-2.1.0 version, then you’ll need to select the repository and set the scheduling options again, but the storage url will be automatically populated once the repository is selected.
If you’re upgrading from 2.1.0 to 2.1.1, then all settings should be kept. Unless you installed Duplicacy differently (install for all users vs install for current user), since the settings are stored in different registry paths (HKLM\Software\Duplicacy vs HKCU\Software\Duplicacy).
