Help with filters file (I attached my file)
I’m testing a backup job of mbox files. Some of this mbox files doesn’t need to be backed up, for exemple: trash, “all mails”, etc. And also some folders doesn’t need, like “cache”.
So i set up a filters file inside the centralized preferences folder:
\preferences\"mbox rep id"\filters (without extension)
where I have lines like:
-All Mail                       (the mbox file)
-All Mail.msf                   (the respective index)
-Trash
-Trash.msf
-/Data/profile/cache2/**    (that have a lot of subfolders)
But I ran a list command and these files and folders are being backed up.
The filters syntax is incorrect?
The path in the filters is always relative to the repository, so -/Data/profile/cache2/** should be Data/profile/cache2/*. -All Mail will on exclude the file in the root of the repository, so if you want to exclude all subdirectories named All Mail the rule should be -*/All Mail/.
Ok! I´ll try this.
I think I didn’t explain well, All Mail is a - big - mbox file, not a directory.
There are several All Mail files, one for each account, as well as several Trash files and so on.
I gave up the wildcard notation and adopted the “regular expression” …
So just to remember: I want to exclude some of the mbox files. They come “in pairs”: a “.msf” file (the index) and a file with the same name and without extension (the mbox file). And these “pairs” appears in several sub-folders (accounts sub-folders).
I also want to exclude the cache folder: D:\......\Data\profile\cache2\
I configured this filters file:
(lines starting with # exclude... were copied from the wiki page)
(lines starting with # ==== are my additions)
# =============== COMMOM FILES ===============
# exclude any cache files/directories with cache in the name (case insensitive)
e:(?i).*cache.*$
# ==== SAME ABOVE, FOR OTHER TYPES
e:(?i).*Thumbs.*$
e:(?i).*desktop.ini*$
# exclude temporary file names
e:.*/?~.*$
# exclude common file types (case insensitive)
e:(?i)\.(bak|mp4|mkv|o|obj|old|tmp)$
# ==== DROPBOX TEMP FILES, I'LL "JOIN" WITH THE OTHERS IN THE LINE ABOVE LATER
e:(?i)\.(dropbox)$
#=============== MBOX "UNWANTED" FILES ===============
# remember: "pairs" in several sub-folders...
e:(?i).*Todos os e-mails.*$
e:(?i).*Todos os e-mails$
e:(?i).*All Mail.*$
e:(?i).*All Mail$
e:(?i).*Importante.*$
e:(?i).*Importante$
e:(?i).*Important.*$
e:(?i).*Important$
e:(?i).*Lixeira.*$
e:(?i).*Lixeira$
e:(?i).*Trash.*$
e:(?i).*Trash$
# ==== MBOX CACHE FOLDER AND ALL ITS FILES AND SUB-FOLDERS
e:Data/profile/cache2/
# include everything else
i:.*
Well, it seems like the cache exclusion is working.
But the msf pair files are still being backed up…
I don’t see anything wrong. Can you run duplicacy -d backup -dry-run to see if there is any more information that can be helpful?
And:
There are 16 compiled regular expressions stored
Loaded 16 include/exclude pattern(s)
Pattern: e:(?i).*cache.*$
Pattern: e:(?i).*Thumbs.*$
Pattern: e:(?i).*desktop.ini*$
Pattern: e:.*/?~.*$
Pattern: e:(?i)\.(bak|mp4|mkv|o|obj|old|tmp|dropbox)$
Pattern: e:(?i)\.(dropbox)$
Pattern: e:(?i).*Todos os e-mails.*$
Pattern: e:(?i).*Todos os e-mails.$
Pattern: e:(?i).*All Mail.$
Pattern: e:(?i).*All Mail$
Pattern: e:(?i).*Importante.*$
Pattern: e:(?i).*Importante.$
Pattern: e:(?i).*Important.*$
Pattern: e:(?i).*Important.$
Pattern: e:Data/profile/cache2/
Pattern: i:.*
Never mind…
Comparing the output file of the -d command above with my today log I found that only the “trash” files were backed up, and it is the only one that was left out of the filters archive, as you can see.
And I just had checked the “trash” files … Murphy’s law…
Thank you, Gilbert.
The filter file now looks like this (in the mbox files part):
e:(?i).*All Mail.*$
e:(?i).*All Mail$
e:(?i).*Importante$
e:(?i).*Important$
e:(?i).*Lixeira.*$
e:(?i).*Lixeira$
e:(?i).*Trash.*$
e:(?i).*Trash$
