Gilbert,
I’m trying to setup a multi storage backup to make some tests, and want to “point” one repository to two different local storages.
Basically I want to backup Evernote repository to a local storage witn 1M variable chunks and another local storage with 1M fixed chunks. So I thinked in doing an init to the first and an add to the second.
Following the instructions of your wiki post about the use of storage-name parameter with two accounts (similar to the case here), I’m trying:
duplicacy init -e -c 1M -pref-dir D:\preferences\"rep-id" -storage-name bkp_1M_VAR "rep_id" "storage_local_path_to_VAR_bkp"
But it is returning me:
Incorrect Usage
Where is my mistake?
And I intend to use
duplicacy add -e -c 1M -max 1M -min 1M -pref-dir D:\preferences\"rep-id" -storage-name bkp_1M_FIX "rep_id" "storage_local_path_to_FIX_bkp"
to the second storage, is that right?
