Help with set and -nobackup-file
Confused by how to set the -nobackup-file option when my repositories were created by the Web UI.
I have one storage configured and 3 different repositories associated with the storage.
In a cmd window I change to the web UI repositories (C:/.duplicacy-web/repositories/localhost/ where = 0, 1 or 2.
run the commad duplicacy.exe set -nobackup_file “nobackup-file.txt”
Checking the preferences file in the repository shows the -nobackup-file option is set.
When I run the backup from the web UI the -nobackup-file option is removed from the repository preference file.
What are the step set the -nobackup-file option for repositories created using web UI?
Those files are regenerated on every run. Don’t modify them.
To set Nobackup file with WebUI see this
You’ll need to edit duplicacy.json, it’s not exposed in UI
Thankyou! That worked.
Needed to know the subtle step of quitting the web GUI before making edits in the duplicacy.json file.
