Hello all, I am fairly new to Duplicacy though I’ve got a script written that I run manually usually monthly. I want to get this set up weekly though I’ve had the tab for the prune command open for probably a year and never got around to figuring it out till now.
Basically what I am trying to do is keep 1 backup per week, and keep the past 4 weekly backups deleting anything older. Theoretically then, I can restore anything I accidentally deleted with not a lot of storage overhead plus grab the most current backup at any point if disaster struck.
My backup is three repositories, one for each drive I backup. I backup from the root of each drive. Each drive is backed up to an external hard drive and then synced to 2 cloud accounts. However two local drives go to the same backup drive. C/D get backed up to Y, E gets backed up to Z.
My first question, is there any optimization I can do to the backup/copying process besides what I already have written?
cd C:
duplicacy_win_x64_2.1.2.exe backup -storage local -vss
duplicacy_win_x64_2.1.2.exe copy -from local -to remote1 -threads 20
duplicacy_win_x64_2.1.2.exe copy -from local -to remote2 -threads 20
Which is repeated for the 2 other drives, D/E.
Finally how do I write the prune command effectively? I am not sure, should I only prune the local storage after it’s backed up, and then copy that to the remote storages? I don’t think that removes it, though, so I’m a bit confused. Do I need 3 lines after the backup/copy as in:
duplicacy_win_x64_2.1.2.exe prune -storage local -keep 0:31 -keep 7:1
duplicacy_win_x64_2.1.2.exe prune -storage remote1 -keep 0:31 -keep 7:1
duplicacy_win_x64_2.1.2.exe prune -storage remote2 -keep 0:31 -keep 7:1
Again repeated for drives D/E?
Then however the prune command documentation said to use -all if multiple repositories back up to the same storage. However I don’t think I did that, simply because mapping one drive to one folder is simpler to manage. I’m not looking for storage efficiency. I initialized each drive root (C/D/E) into a separate folder with that drive letter on the backup drives. So, I don’t think I need to use -all?
I am sorry for these noob questions but guidance would be really appreciated.
Thank you!
If the former, you’ll have multiple repositories in each of the two remotes. That’s why you may have to use
