How do i configure a retention policy (web edition)
HI,
I’ve just installed Duplicacy web edition and i’e got 2 backups running (Same source but one to cloud and one to local).
What i’m having problems with is how do i set a retention policy? I can’t find any options anywhere in the gui.
You need to schedule a prune job, the same way as you did for a backup job. The dialog will offer a default retention policy you can customize, and it can be customized further after adding the job. The options are detailed here: Prune command details
