Hello, I’m using Duplicacy to backup to remote Qnap NAS via WebDav protocol. I was fine for couple years, but recently I noticed that check and prune commands started to fail. Backup work fine, but listing chunks ends with timeouts or connection reset. I probably reached some Qnap performance limits (backup have 125 000 chunks)
My question:
Is there some way I can increase Duplicacy timeouts or slow down check command? Or something else I can do on Duplicacy side? Thanks
This is log I’m getting from check command:
Running check command from .duplicacy-web/repositories/localhost/all
Options: [-log -v check -storage abc -persist -id t_down]
2024-04-21 13:47:49.964 INFO STORAGE_SET Storage set to webdav://webdavtarget.com:5001/USBDisk1/Duplicacy/targetfolder
2024-04-21 13:47:53.120 TRACE WEBDAV_MKDIR Can't create directory snapshots: Moved permanently; error ignored
2024-04-21 13:47:53.151 TRACE WEBDAV_MKDIR Can't create directory chunks: Moved permanently; error ignored
2024-04-21 13:47:53.212 TRACE CONFIG_ITERATIONS Using 123 iterations for key derivation
2024-04-21 13:47:53.266 INFO SNAPSHOT_CHECK Listing all chunks
2024-04-21 13:47:53.266 TRACE LIST_FILES Listing chunks/
2024-04-21 13:47:53.390 TRACE LIST_FILES Listing chunks/37/
2024-04-21 13:47:53.520 TRACE LIST_FILES Listing chunks/ea/
2024-04-21 13:47:53.651 TRACE LIST_FILES Listing chunks/51/
2024-04-21 13:47:53.738 TRACE LIST_FILES Listing chunks/87/
2024-04-21 13:47:53.852 TRACE LIST_FILES Listing chunks/25/
2024-04-21 13:47:53.963 TRACE LIST_FILES Listing chunks/d8/
2024-04-21 13:47:54.086 TRACE LIST_FILES Listing chunks/c6/
2024-04-21 13:47:54.866 TRACE LIST_FILES Listing chunks/ab/
2024-04-21 13:48:25.758 TRACE LIST_FILES Listing chunks/a5/
2024-04-21 13:48:50.441 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/a5/' returned an error (Propfind "https://webdavtarget.com": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:49:12.229 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/a5/' returned an error (Propfind "https://webdavtarget.com": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:49:34.394 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/a5/' returned an error (Propfind "https://webdavtarget.com": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:49:57.433 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/a5/' returned an error (Propfind "https://webdavtarget.com": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:50:23.585 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/a5/' returned an error (Propfind "https://webdavtarget.com": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:50:49.316 TRACE LIST_FILES Listing chunks/7a/
2024-04-21 13:50:49.490 TRACE LIST_FILES Listing chunks/76/
2024-04-21 13:50:49.623 TRACE LIST_FILES Listing chunks/3c/
2024-04-21 13:50:49.677 TRACE LIST_FILES Listing chunks/3b/
2024-04-21 13:50:49.794 TRACE LIST_FILES Listing chunks/df/
2024-04-21 13:50:49.910 TRACE LIST_FILES Listing chunks/af/
2024-04-21 13:50:49.993 TRACE LIST_FILES Listing chunks/86/
2024-04-21 13:50:50.655 TRACE LIST_FILES Listing chunks/52/
2024-04-21 13:50:51.287 TRACE LIST_FILES Listing chunks/bc/
2024-04-21 13:51:43.297 TRACE LIST_FILES Listing chunks/b6/
2024-04-21 13:52:05.501 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/b6/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/b6/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:52:27.453 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/b6/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/b6/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:52:50.413 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/b6/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/b6/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:53:14.289 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/b6/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/b6/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:53:39.915 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/b6/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/b6/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:54:03.709 TRACE LIST_FILES Listing chunks/57/
2024-04-21 13:54:03.845 TRACE LIST_FILES Listing chunks/f8/
2024-04-21 13:54:03.945 TRACE LIST_FILES Listing chunks/b5/
2024-04-21 13:54:04.035 TRACE LIST_FILES Listing chunks/a6/
2024-04-21 13:54:04.145 TRACE LIST_FILES Listing chunks/7e/
2024-04-21 13:54:04.351 TRACE LIST_FILES Listing chunks/79/
2024-04-21 13:54:04.492 TRACE LIST_FILES Listing chunks/8e/
2024-04-21 13:54:05.326 TRACE LIST_FILES Listing chunks/fb/
2024-04-21 13:54:06.362 TRACE LIST_FILES Listing chunks/5b/
2024-04-21 13:54:07.005 TRACE LIST_FILES Listing chunks/9a/
2024-04-21 13:54:49.791 TRACE LIST_FILES Listing chunks/97/
2024-04-21 13:55:11.105 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/97/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/97/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:55:32.760 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/97/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/97/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:55:55.339 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/97/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/97/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:56:19.821 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/97/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/97/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:56:36.071 TRACE LIST_FILES Listing chunks/5a/
2024-04-21 13:56:36.205 TRACE LIST_FILES Listing chunks/da/
2024-04-21 13:56:36.317 TRACE LIST_FILES Listing chunks/b4/
2024-04-21 13:56:36.427 TRACE LIST_FILES Listing chunks/6e/
2024-04-21 13:56:36.554 TRACE LIST_FILES Listing chunks/6d/
2024-04-21 13:56:36.688 TRACE LIST_FILES Listing chunks/1f/
2024-04-21 13:56:36.800 TRACE LIST_FILES Listing chunks/8a/
2024-04-21 13:56:37.596 TRACE LIST_FILES Listing chunks/81/
2024-04-21 13:57:20.493 TRACE LIST_FILES Listing chunks/67/
2024-04-21 13:57:43.757 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/67/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/67/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:58:05.691 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/67/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/67/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:58:28.320 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/67/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/67/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:58:52.569 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/67/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/67/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:59:20.213 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/67/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/67/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 13:59:54.972 TRACE WEBDAV_ERROR URL request 'PROPFIND chunks/67/' returned an error (Propfind "https://webdavtarget.com/targetfolder/chunks/67/": dial tcp 123.123.123.123:5001: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.)
2024-04-21 14:00:26.270 TRACE LIST_FILES Listing chunks/27/
2024-04-21 14:00:26.332 TRACE LIST_FILES Listing chunks/22/
2024-04-21 14:00:26.445 TRACE LIST_FILES Listing chunks/0b/
2024-04-21 14:00:26.586 TRACE LIST_FILES Listing chunks/ba/
2024-04-21 14:00:26.681 TRACE LIST_FILES Listing chunks/ce/
2024-04-21 14:00:26.779 TRACE LIST_FILES Listing chunks/63/
2024-04-21 14:00:26.904 TRACE LIST_FILES Listing chunks/4d/
2024-04-21 14:00:27.054 TRACE LIST_FILES Listing chunks/b3/
2024-04-21 14:00:27.837 TRACE LIST_FILES Listing chunks/95/
2024-04-21 14:02:40.095 ERROR LIST_FILES Failed to list the directory chunks/95/: read tcpsourceIP:53474->123.123.123.123:5001: wsarecv: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
