Following the suggestion in the latest release notes I’m checking the chunks on my sftp server.
I started the check command 24 hours ago. duplicacy checked that all chunks existed successfully, then stated Verifying 421147 chunks and has been sitting there like that.
duplicacy check -all -chunks -threads 4
<snip>
All chunks referenced by snapshot userland at revision 67 exist
I’m running the cli on the server itself. (Its no speed demon, 1.5ghz dual core AMD Turion II.)
Just wondering if anyone knows how long it will take.
I can still see duplicacy process in htop and they.re sucking up most of the cpu, so it seems its running ok.
