New user here so forgive me if this is normal behaviour for the program but I just wanted to double check it is before moving forward.
I have a 1.54tb backup on local storage, just one snapshot so far. I wanted to try the ‘Check’ command (via the webGUI). So I scheduled this and manually started it with options: -chunks - stats.
After 8 hours it hadn’t finished so I aborted the operation. After checking the log files, it appears to have been 65% through the operation (If i’m reading it correctly). This is the last line:
-11 05:42:44.089 INFO VERIFY_PROGRESS Verified chunk a7ce205b025ea705a4b49324cc14a328cd10f7954d3c990957ba047452028947 (199611/309514), 36.09MB/s 04:12:03 64.5%
So I’m guessing that if left to run, it would have taken a total of around 12 hours to complete. Is this about right for a 1.54tb snapshot?
