How to avoid "Creating directory snapshots/xxxx" when using "duplicacy list"
Hi all.
When runing duplicacy list, “Creating directory snapshots/xxxx” message appears.
Can’t figure out the meaning of this message.
Is there a way to avoid it because I’d like to use the duplicacy list output.
Sample :
duplicacy list,
Storage set to smb://jerome@ocean/backup/duplicacy
Creating directory snapshots/home/
Snapshot home revision 1 created at 2025-10-15 12:49 -hash
Snapshot home revision 2 created at 2025-10-15 22:04
Snapshot home revision 3 created at 2025-10-16 18:03
etc.
Best regards.
At a guess, this is probably just creating the directory structure in the cache - which is kinda necessary in order to do a list. But you’re probably only seeing this if you using -v or -d anyway.
I just launch a duplicacy list without option.
My goal is to generate reports then sending a report email.
Could it be due to the smb storage?
Hi all,
When using duplicacy list Creating directory snapshots/ messages appears.
Can’t figure out the utility of these messages and how to avoid them to reuse command line output.
Any ideas???
Max OSX 15.7.1 / Duplicacy 3.2.5 (2DEF01) ARM version
Sample :
duplicacy list
Etc…
If you don’t need them - ignore them?
What are you trying to accomplish?
I will clean the report by script but it appears sometimes during a “duplicacy backup” too.
I notice that these messages only appear when I use the -log option; otherwise, they do not appear.
As they don’t have an ID, they can’t be removed by the -suppress option,
