I have few directories containing documents that sometimes get moved from one to another. I would like to backup the both directory trees to the same backup destination (B2 Bucket) to save in data transfer time in case documents get moved form one directory-tree to another.
Should I:
- init the backup two times (once for each directory) for the same repository ?
OR
- Use symlinks and create a separate (artificial) “root” directory and place the symlinks there pointing to the root of both the directories?
If the approach #1 also works, can I backup partially overlapping repositories from different computers to the same backup Storage? I mean the case were some computers have only subset of the total content in a repository.
