Hello,
ls there any method to check in which snapshot/revision is a chunk referenced without running check (which is very slow - runs for many hours, overlaping with backup window).
I have a backup which fails because of a single chunk is missing (it is not in cache either ) and I would like to know where is referenced in order to delete/prune.
Check should be fast unless there is a -chunks or -files option. Which storage backend are you using?
You can add -d as a global option to the check job which will produce more log messages.
