I noticed my email notifications are no longer working, but the log reports email sent (it should probably report a failure if the FQDN could not be resolved).
I suspect it is because I changed the SMTP server FQDN, and I wanted to change the config to use an IP instead of FQDN, but I can’t figure out how to edit settings in the web UI?
If it is possible to edit settings for already configured backups, how?
If not, I can edit the JSON config file directly, where can I find docs on the config options?
