I’ve got about 27TB of data, 4m+ chunks. Trying to run a check command (-threads 16) on the repository that is on a local NAS, connecting via SMB. it has now been stuck on ‘listing chunks’ for 6 hours. CPU 0-2% on the whole system, 3GB ram usage on the whole system (win 10 VM). So basically the machine is idle. Is it really still listing or is it stuck ? How do I troubleshoot this ? How do I unstuck it ?
while this check command has been ‘running’ everything else seems to be functioning fine, running other parallel backups works, but very slowly, clearly though, it’s not a complete crash.
The backups do run like they should now. The check used to work before though. What I wonder is if the messing with the clock could have messed with duplicacy’s ability to read the backups? because some of them will have timestemps going back and forward in time ?
