How do you get the WebUI to use normal time input? For some reason it prevents regular HH:mm input and forces you to use some strange backward am/pm thing? Even more bemusing it seems to capitalise Pm and not am. I can’t find the setting to go to standard time formats.
Even worse, on my PC, it won’t let me type numbers using the numpad and only accepts input from the number row which is just bemusing.
Can we have cron format as well?
