How to reduce storage size?
Hi all. I’ve been using Duplicacy to backup to Backblaze for… maybe a year now? A while anyway. Generally it works great and is very reliable. However, my Backblaze usage keeps growing and growing and growing… It’s up to 3.6 Tb now because I had never set up a prune job or limited the number of revisions(?). (I’m not entirely sure about the correct terminology here.)
My backup job log looks likes this:
Options: [-log backup -storage Backblaze-B2 -threads 4 -limit-rate 3000 -stats -stats]
2023-09-03 03:00:01.642 INFO REPOSITORY_SET Repository set to /backuproot
2023-09-03 03:00:01.642 INFO STORAGE_SET Storage set to b2://grigsby-citadel-duplicacy
2023-09-03 03:00:01.765 INFO BACKBLAZE_URL download URL is: https://f000.backblazeb2.com
2023-09-03 03:00:03.159 INFO BACKUP_START Last backup at revision 287 found
2023-09-03 03:00:04.262 INFO BACKUP_INDEXING Indexing /backuproot
So there are roughly 287 revisions, which is way more than I need. I’d like to reduce my Backblaze usage to about a month’s worth of backups.
A few weeks ago I added a prune job to run once a week with the following arguments:
-log prune -storage Backblaze-B2 -keep 0:30
The log says
2023-08-30 06:00:01.306 INFO STORAGE_SET Storage set to b2://grigsby-citadel-duplicacy
2023-08-30 06:00:01.449 INFO BACKBLAZE_URL download URL is: https://f000.backblazeb2.com
2023-08-30 06:00:02.948 INFO RETENTION_POLICY Keep no snapshots older than 30 days
2023-08-30 06:00:12.045 INFO SNAPSHOT_NONE No snapshot to delete
So my Backblaze usage hasn’t gone down, and duplicacy seems to think there’s nothing to delete. What am I doing wrong? How do I run a prune command to delete everything older than 30 days?
Thank you very much!
You are doing it right, it’s not clear why does prune think there are no eligible snapshots.
I would try adding -d global option to prune command to see more detailed log.
Can you connect to b2 with some other tool like Cyberduck and confirm that there are actually snapshots in the bucket older than 30 days? The prefix would be snapshots/snapshot-id/…
Another one — pass specific snapshot id to prune command, not just rely on the default, or pass -a flag, to prune all snapshot ids
Thank you for the suggestions! I appreciate the pointers on where and how to keep investigating. I’ll keep working on it…
Keep in mind Duplicacy won’t remove chunks until after the second step in the fossil collection process. So you’d have to run a whole round of backups and then another prune before those fossilised chunks actually get deleted.
Are your prune logs above from your first run? That’s the only explanation I can think of it - you should have seen snapshot revisions get deleted at least, and then chunks renamed to .fsl.
I did read that it won’t prune after the first run for the reasons you stated, but the prune job has run three or four times now. Thank you for the suggestion! I’ll keep looking into it.
You can run as many prunes as you like, but there must be a round of full backups between them. This ensures the marked fossils (collected) are definitely not used in subsequent backups…
