In the GUI ‘Restore’ tab, there appears to no way to add storage to restore from.
If a machine is lost, and you go to a replacement machine to restore the files, the GUI doesn’t seem to have any way to restore those files?
On the new machine, you can set it to use the same storage. And then once you click ‘List Revisions’ you can choose the original repository id from the repository id list. From there you can select a revision and click ‘List Files’ to list all file in the selected revision.
