Thank you for the explanation — as you can probably guess, I have never used flock before
How would start-stop-daemon handle stopping the daemon when duplicacy is in the middle of backing up?
In situations like this, I tend to use a signal file.
while test ! -f /var/run/stop.backup ; do
done
rm /var/run/stop.backup
You could write an /etc/init.d/backupservice script to handle starting and stopping the daemon.
start-stop-daemon sends a SIGTERM signal when you tell it to stop a process (you can also change and send a different signal via the --signal flag).
You can trap this right before starting Duplicacy:
trap "" SIGTERM
/usr/local/bin/duplicacy -log backup -stats
trap - SIGTERM
I believe this effectively “shields” Duplicacy from being killed (unless a more harsh SIGKILL is used). This also works for services: stopping a service sends SIGTERM initially.
But then the service won’t stop at all as it will just ignore the SIGTERM.
This works with SIGTERM
#!/bin/bash
STOP=false
while : ; do
$STOP && break
trap 'STOP=true' SIGTERM
echo "$(date) sleep 10"
echo "$(date) done sleep"
trap - SIGTERM
done
echo "$(date) exiting..."
Good point - you also probably don’t need trap - SIGTERM, you can just trap it immediately when the process starts and use the variable as the condition:
trap 'stop=1' SIGTERM
while test -z "$stop" ; do
echo "$(date) starting"
echo "$(date) done"
sleep 3600
done
echo "$(date) got sigterm..."
