Howdy, getting an error. not sure how to resolve
Back up C:/DATA@localhost to storage FSSERVER1-NEW, status: Failed, log file: backup-20250518-020001.log
Running backup command from C:\ProgramData/.duplicacy-web/repositories/localhost/1 to back up C:/DATA
Options: [-log backup -storage FSSERVER1-NEW -threads 60 -vss -vss-timeout 360 -stats]
2025-05-18 02:00:01.939 INFO REPOSITORY_SET Repository set to C:/DATA
2025-05-18 02:00:01.941 INFO STORAGE_SET Storage set to s3://[us-east-1@s3.us-east-1.amazonaws.com/data.floridaseating.com](http://us-east-1@s3.us-east-1.amazonaws.com/data.floridaseating.com)
2025-05-18 02:00:02.781 INFO BACKUP_START Last backup at revision 390 found
2025-05-18 02:00:03.365 INFO VSS_CREATE Creating a shadow copy for C:\
2025-05-18 02:00:18.713 INFO VSS_DONE Shadow copy {1CBDEBC3-5129-4212-A00C-4CEB019B9586} created
2025-05-18 02:00:18.715 INFO BACKUP_INDEXING Indexing C:\DATA
2025-05-18 02:00:18.716 INFO SNAPSHOT_FILTER Parsing filter file \\?\C:\ProgramData\.duplicacy-web\repositories\localhost\1\.duplicacy\filters
2025-05-18 02:00:18.716 INFO SNAPSHOT_FILTER Loaded 0 include/exclude pattern(s)
2025-05-18 02:04:40.977 ERROR UPLOAD_CHUNK Failed to upload the chunk a3fbf5f6c343138d7bc4e3b10767c9c97dc163542256f4bc10a1a7d331e6bb6f: RequestError: send request failed
caused by: Put "[https://s3.us-east-1.amazonaws.com/data.floridaseating.com/chunks/a3/fbf5f6c343138d7bc4e3b10767c9c97dc163542256f4bc10a1a7d331e6bb6f":](https://s3.us-east-1.amazonaws.com/data.floridaseating.com/chunks/a3/fbf5f6c343138d7bc4e3b10767c9c97dc163542256f4bc10a1a7d331e6bb6f%22:) write tcp 192.168.1.220:17731->[52.217.96.14:443](http://52.217.96.14:443/): wsasend: An existing connection was forcibly closed by the remote host.
2025-05-18 02:04:40.977 ERROR UPLOAD_CHUNK Failed to upload the chunk 51030846fc4764e5bd59afc869be8877473aa006bd3812faebf48711f35c1d66: RequestError: send request failed
caused by: Put "[https://s3.us-east-1.amazonaws.com/data.floridaseating.com/chunks/51/030846fc4764e5bd59afc869be8877473aa006bd3812faebf48711f35c1d66":](https://s3.us-east-1.amazonaws.com/data.floridaseating.com/chunks/51/030846fc4764e5bd59afc869be8877473aa006bd3812faebf48711f35c1d66%22:) write tcp 192.168.1.220:17678->[3.5.0.12:443](http://3.5.0.12:443/): wsasend: An existing connection was forcibly closed by the remote host.
2025-05-18 02:04:40.977 ERROR UPLOAD_CHUNK Failed to upload the chunk 21994169e30656f1773732eacf7b4b2d1b3e24be197a4dbb19737c41c05f7cdb: RequestError: send request failed
caused by: Put "[https://s3.us-east-1.amazonaws.com/data.floridaseating.com/chunks/21/994169e30656f1773732eacf7b4b2d1b3e24be197a4dbb19737c41c05f7cdb":](https://s3.us-east-1.amazonaws.com/data.floridaseating.com/chunks/21/994169e30656f1773732eacf7b4b2d1b3e24be197a4dbb19737c41c05f7cdb%22:) read tcp 192.168.1.220:17764->[52.217.42.238:443](http://52.217.42.238:443/): wsarecv: An existing connection was forcibly closed by the remote host.
Failed to upload the chunk a3fbf5f6c343138d7bc4e3b10767c9c97dc163542256f4bc10a1a7d331e6bb6f: RequestError: send request failed Failed to upload the chunk 51030846fc4764e5bd59afc869be8877473aa006bd3812faebf48711f35c1d66: RequestError: send request failed Failed to upload the chunk 21994169e30656f1773732eacf7b4b2d1b3e24be197a4dbb19737c41c05f7cdb: RequestError: send request failed
Try reducing number of threads.
thank you! that did it. oddly, it has been set as 60 for years. something may have changed on provider.
