Hi all,
I have been using and loving Duplicacy for about 12 months now. The best backup solution for my needs - so glad I found it.
I use it to backup a bunch of data from a desktop to a QNAP. I then use FreeFileSync to periodically mirror the Duplicacy backed up data from the QNAP to a pair of external hard drives for additional copies / protection.
This method takes ages and keeps all the drives really busy (more wear?) as it needs to check all files from the source and destination before it can update the external to make it an exact copy.
Is there are a faster / more efficient way to do this, perhaps something taking advantage of the immutability properties of the Duplicacy specification?
Any advice appreciated.
