I believe this started after upgrading an Intel Mac to Ventura (13). I have a pretty simple backup that goes to an external flash drive, which is then copied to a remote location (OneDrive). I’m using the Web UI.
I expect the backup to succeed.
The backup fails with this error in the log:
2022-12-08 18:52:20.700 ERROR UPLOAD_CHUNK Failed to upload the chunk 5fafd9017a4902ed9f179366075dd7e2d75025e2c5b9a45e2935272ca272220c: sync /Volumes/RED FLASH/Mac Duplicacy Backup Data/chunks/5f/afd9017a4902ed9f179366075dd7e2d75025e2c5b9a45e2935272ca272220c.npjyplpv.tmp: inappropriate ioctl for device
The check command is able to succeed, so it seems like Duplicacy can read the drive and all of the data is fine, but it can’t write.
I did fsck on the disk and it had no problems.
“Duplicacy Web Edition” has Full Disk Access; I also tried adding the duplicacy CLI but that didn’t help.
needs to introduce some code changes to work around that.
. Given how old FAT32 is, you’d think they’d leave that code alone.
