Hi All, I am a new Duplicacy convert from CrashPlan and I am seeing very slow backup speeds but cannot figure out what the bottleneck is.
I have read through a number of different threads including this github issue and this optimization thread. From the discussion in the second link, I realized I should use only a single thread since I am backing up from a hard drive and I did see about a 50% speed improvement at steady state. However, I am still only getting about 150kB/s at the moment and my modest 400 GB backup says it is going to take 20 days.
A couple notes about my setup - I am running Ubuntu 16.04 with Duplicacy running inside a docker container. I have a dual core CPU (which hovers around 2% usage) with 8 GB of RAM and am backing up from a 2x2TB Raid 1 array (software raid).
As far as I can tell, there are plenty of resources available to the backup engine and I am stumped as to what would be causing such low speeds, especially when some of the other threads are reporting speeds in the 1-10 MB/s range.
Any suggestions would be appreciated!
