I’m testing out duplicacy for offsite backups of my important zfs datasets in the cloud.
I’ve went to the root of an zfs dataset and initialized a new repository and uploaded an backup.
sudo -i
cd /home
duplicacy init -e -key /tmp/public.pem -erasure-coding 5:2 -zstd -storage-name backblaze-eu-central-backups elitebook-840-g6-raccoon-data-home b2://racc-duplicacy-backups
duplicacy backup -stats -threads 16 -zstd -storage backblaze-eu-central-backups
After the initial backup succeeds and some incremental backups I’ve decided to actually test restoring the dataset.
sudo -i
mkdir /mnt/test_home_restore
zfs create raccoon/TEST_HOME_RESTORE
zfs set mountpoint=/mnt/test_home_restore raccoon/TEST_HOME_RESTORE
zfs mount raccoon/TEST_HOME_RESTORE
mount | grep test
# raccoon/TEST_HOME_RESTORE on /mnt/test_home_restore type zfs (rw,nodev,relatime,xattr,posixacl,casesensitive)
cd /mnt/test_home_restore/
duplicacy init -e -key /tmp/public.pem -erasure-coding 5:2 -zstd -storage-name backblaze-eu-central-backups -repository /mnt/test_home_restore elitebook-840-g6-raccoon-data-home b2://racc-duplicacy-backups
# Enter Backblaze account or application id:***********
# Enter corresponding Backblaze application key:*******
# Download URL is: https://f003.backblazeb2.com
# Enter storage password for b2://racc-duplicacy-backups:********************************
# The storage 'b2://racc-duplicacy-backups' has already been initialized
# This storage is configured with an invalid compression level 201
ls -la .duplicacy/
# total 1
# drwxr--r-- 2 root root 2 Sep 11 22:02 ./
# drwxr-xr-x 3 root root 3 Sep 11 22:02 ../
duplicacy list
# Failed to read the preference file from repository /mnt/test_home_restore: open /mnt/test_home_restore/.duplicacy/preferences: no such file or directory
The repository initializes and I’m able to access my backups.
The repository doesn’t initializes. The initialization fails with “This storage is configured with an invalid compression level 201”
