When runnig duplicacy init -e test "swift://SBI-XXXXXX@swiss-backup.infomaniak.com/identity/v3?domain=default&tenant=sb_project_XXXXXX" I’m asked to enter the OpenStack Swift key, and after doing so the result is:
runtime error: invalid memory address or nil pointer dereference
goroutine 1 [running]:
runtime/debug.Stack(0x41, 0x0, 0x0)
/usr/local/go/src/runtime/debug/stack.go:24 +0xa4
runtime/debug.PrintStack()
/usr/local/go/src/runtime/debug/stack.go:16 +0x29
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/src/duplicacy_log.go:224 +0xf5
panic(0xea0fe0, 0x1a5b4c0)
/usr/local/go/src/runtime/panic.go:522 +0x1c3
sync.(*Mutex).Lock(0x0)
/usr/local/go/src/sync/mutex.go:74 +0x34
github.com/gilbertchen/duplicacy/vendor/github.com/ncw/swift.(*Connection).storage(0xc0003f0000, 0x0, 0x0, 0x0, 0x0, 0xfdc37f, 0x4, 0x0, 0x0, 0xc0003be000, .
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/vendor/github.com/ncw/swift/swift.go:816 +0x86
github.com/gilbertchen/duplicacy/vendor/github.com/ncw/swift.(*Connection).Container(0xc0003f0000, 0x0, 0x0, 0x8, 0x1a90be0, 0xc000078085, 0x2b, 0xc000142e80
, 0x33, 0x45f9a0)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/vendor/github.com/ncw/swift/swift.go:1308 +0xde
github.com/gilbertchen/duplicacy/src.CreateSwiftStorage(0xc000078078, 0x38, 0xc0003bc270, 0x8, 0x1, 0x0, 0xc000078070, 0x6e)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/src/duplicacy_swiftstorage.go:132 +0x994
github.com/gilbertchen/duplicacy/src.CreateStorage(0xfdf358, 0x7, 0xc00002a0f8, 0x4, 0x0, 0x0, 0xc000078070, 0x6e, 0x1, 0x0, ...)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/src/duplicacy_storage.go:671 +0x4700
main.configRepository(0xc0003b85a0, 0xc0003b8501)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/duplicacy/duplicacy_main.go:337 +0x6d7
main.initRepository(0xc0003b85a0)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/duplicacy/duplicacy_main.go:232 +0x37
github.com/gilbertchen/duplicacy/vendor/github.com/gilbertchen/cli.Command.Run(0xfdc76b, 0x4, 0x0, 0x0, 0x0, 0x0, 0x0, 0x101c925, 0x4f, 0x0, ...)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/vendor/github.com/gilbertchen/cli/command.go:160 +0x754
github.com/gilbertchen/duplicacy/vendor/github.com/gilbertchen/cli.(*App).Run(0xc0003b8120, 0xc00003c080, 0x5, 0x8, 0x0, 0x0)
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/vendor/github.com/gilbertchen/cli/app.go:179 +0x656
main.main()
/Users/chgang/zincbox/go/src/github.com/gilbertchen/duplicacy/duplicacy/duplicacy_main.go:2129 +0x614e
This is using version 2.6.2 och duplicacy CLI on Windows. Does not appear to matter much what I write after the swift:// protocol specifier, the result always appears to be a nil pointer dereference error.
