Is it possible to prevent OS X Web Edition to open a Safari window on startup?
Everytime I startup my Mac, I will get the Duplicacy Web Edition interface to popup in a Safari window. Is there a way to have it start “silently”?
Thanks a lot
Version 1.1.0 can do this, which will be released over the weekend but you can download it from here now:
https://acrosync.com/duplicacy-web/duplicacy_web_osx_x64_1.1.0.dmg
After you select Start on login, edit ~/Library/LaunchAgents/duplicacy-web.plist to pass a -background option to the program:
    <key>ProgramArguments</key>
      <array>
        <string>/Applications/Duplicacy Web Edition.app/Contents/MacOS/duplicacy_web_osx_x64</string>
        <string>-background</string>
      </array>
Awesome. I ask and BAM, it’s here the next weekend :wink:
Thank you
For anyone: Feel free to use the :heart: button on the posts that you found useful.
For the OP of any #support topic: you can mark the post that solved your issue by ticking the :checked: under the post. That of course may include your own post :slight_smile:
