I downloaded the GUI for OS X yesterday, and was playing around with backing up to the B2 bucket. I delete the files on B2 to try another approach, and now it says that Duplicacy is no longer in the trial version mode, so I can no longer access the program. Is there a way I can reset this so I can continue with the trial? Your software looks very promising, but I keep running into roadblocks along the way. Thanks for your help!
You can run ‘defaults delete com.acrosync.mac.duplicacy License’ in Terminal to remove the old trial license. When Duplicacy restarts it will download a new one that should work.
Thank you. That worked perfectly.
