is there a full list of ids somewhere that can be used for the -suppress switch?
The full list isn’t documented anywhere, but you can find out by running grep on the source code such as:
grep LOG_INFO src/*.go duplicacy/*.go
Thank you, @gchen
Atm, these are the ones:
LOG_ASSERT
LOG_DEBUG
LOG_DEFAULT
LOG_DIR
LOG_ERROR
LOG_FATAL
LOG_FILE
LOG_INFO
LOG_TRACE
LOG_WARN
No, these are logging levels (which are controlled by -v or -d). The log id is the first argument passed to the logging functions.
Ah. Ok!
More like this:
ACD_RETRY
AZURE_RETRY
B2_RETRIES
BACKBLAZE_URL
BACKUP_END
BACKUP_INDEXING
BACKUP_KEY
BACKUP_LIST
BACKUP_START
BACKUP_STATS
BACKUP_THREADS
BENCHMARK_DELETE
BENCHMARK_DOWNLOAD
BENCHMARK_GENERATE
BENCHMARK_READ
BENCHMARK_SPLIT
BENCHMARK_UPLOAD
BENCHMARK_WRITE
CHUNK_BUFFER
CHUNK_DELETE
CHUNK_REDUNDANT
CHUNK_SPLIT
CHUNK_TEMPORARY
CHUNK_UNREFERENCED
CONFIG_CLEAN
CONFIG_EXIST
CONFIG_INFO
CONFIG_SAVE
DELETE_FILE
DOWNLOAD_DONE
DOWNLOAD_PROGRESS
FILE_SKIP
FOSSIL_COLLECT
FOSSIL_DELETABLE
FOSSIL_DELETE
FOSSIL_GHOSTSNAPSHOT
FOSSIL_IGNORE
FOSSIL_NONE
FOSSIL_POSTPONE
FOSSIL_RECREATE
FOSSIL_REFERENCED
FOSSIL_RESURRECT
FOSSIL_UNREFERENCED
GCD_RETRY
GCS_RETRY
HUBIC_CALL
HUBIC_RETRY
INCOMPLETE_LOAD
INCOMPLETE_SAVE
LIST_ATTRIBUTES
LIST_FILES
LOG_DEFAULT
ONEDRIVE_RETRY
PACK_END
PASSWORD_MISSING
PRUNE_NEWSNAPSHOT
REPOSITORY_INIT
REPOSITORY_SET
RESTORE_DELETE
RESTORE_END
RESTORE_INPLACE
RESTORE_START
RESTORE_STATS
RETENTION_POLICY
S3_RETRY
SCRIPT_OUTPUT
SCRIPT_RUN
SNAPSHOT_CHECK
SNAPSHOT_CHUNKS
SNAPSHOT_COPY
SNAPSHOT_DELETE
SNAPSHOT_DIFF
SNAPSHOT_EXIST
SNAPSHOT_FAIL
SNAPSHOT_FILE
SNAPSHOT_FILTER
SNAPSHOT_FILTER
SNAPSHOT_HISTORY
SNAPSHOT_INACTIVE
SNAPSHOT_INFO
SNAPSHOT_NONE
SNAPSHOT_NOT_CONSIDERED
SNAPSHOT_STATS
SNAPSHOT_VALIDATE
SNAPSHOT_VERIFY
SSH_CERTIFICATE
SSH_PUBLICKEY
STORAGE_CHUNK
STORAGE_CONFIGURED
STORAGE_DELETE
STORAGE_ENCRYPTED
STORAGE_FORMAT
STORAGE_FOSSIL
STORAGE_LIST
STORAGE_NOT_INITIALIZED
STORAGE_SET
STORAGE_SET
STORAGE_SNAPSHOT
STORAGE_TEST
TEMPORARY_DELETE
UNREFERENCED_CHUNK
UPLOAD_CHUNK
UPLOAD_FILE
UPLOAD_KEEPALIVE
UPLOAD_PROGRESS
VSS_CREATE
VSS_DELETE
VSS_DONE
WEBDAV_RETRY
