The last 2 weeks or so I keep have a problem with my local copy schedule. It says “killed”. the log file is below. ID of backup changed. This schedule is getting killed only after 2 minutes when nothing else on the machine is running. I have 4GB of RAM. CLI version is 2.6.1 and web version is 1.4.1. running in docker image.
Running backup command from /var/cache/duplicacy/repositories/localhost/0 to back up /source
Options: [-log backup -storage USB -threads 2 -stats]
2020-12-27 00:00:01.445 INFO REPOSITORY_SET Repository set to /source
2020-12-27 00:00:01.445 INFO STORAGE_SET Storage set to /USB/XXXXXXXXXXXXXXXXX
2020-12-27 00:00:32.421 INFO BACKUP_START Last backup at revision 153 found
2020-12-27 00:00:32.421 INFO BACKUP_INDEXING Indexing /source
2020-12-27 00:00:32.421 INFO SNAPSHOT_FILTER Parsing filter file /var/cache/duplicacy/repositories/localhost/0/.duplicacy/filters
2020-12-27 00:00:32.452 INFO SNAPSHOT_FILTER Loaded 5 include/exclude pattern(s)
2020-12-27 00:00:36.967 WARN LIST_SKIP Skipped non-regular file mariadb1/mysqld.sock
2020-12-27 00:02:17.386 INFO BACKUP_THREADS Use 2 uploading threads
signal: killed
