Set -max-chunk-size to 2048M or greater with encryption enabled.
Either a fail on init (“chunk size too large” or similar message) or work like normal.
Once backup is run, it will eventually fail with:
Failed to encrypt the chunk <hash>: LZ4 compression error: input too large
