ERROR Failed to Configure the storage: Maximum backoff reached
Can you turn on the Verbose logging option, try it again, and then post the logs here?
23:12:49.000 Command: duplicacy -background -log -d info -repository "C:\Users\Aloha" "b2://Andrew”
23:12:49.938 Reading the environment variable DUPLICACY_B2_ID
23:12:49.938 Reading the environment variable DUPLICACY_B2_KEY
23:12:51.250 The storage has not been initialized
23:12:52.000 Command: duplicacy -background -log -d init ALOHA "b2://Andrew”
23:12:52.095 Reading the environment variable DUPLICACY_B2_ID
23:12:52.095 Reading the environment variable DUPLICACY_B2_KEY
23:12:53.745 URL request 'https://pod-000-1041-02.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001041_t0005' returned an error: Post https://pod-000-1041-02.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001041_t0005: x509: certificate signed by unknown authority
23:12:55.083 URL request 'https://pod-000-1041-16.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001041_t0057' returned an error: Post https://pod-000-1041-16.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001041_t0057: x509: certificate signed by unknown authority
23:12:57.481 URL request 'https://pod-000-1042-13.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001042_t0057' returned an error: Post https://pod-000-1042-13.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001042_t0057: x509: certificate signed by unknown authority
23:13:01.852 URL request 'https://pod-000-1013-15.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001013_t0029' returned an error: Post https://pod-000-1013-15.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001013_t0029: x509: certificate signed by unknown authority
23:13:10.261 URL request 'https://pod-000-1041-15.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001041_t0022' returned an error: Post https://pod-000-1041-15.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001041_t0022: x509: certificate signed by unknown authority
23:13:26.584 URL request 'https://pod-000-1039-10.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001039_t0059' returned an error: Post https://pod-000-1039-10.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001039_t0059: x509: certificate signed by unknown authority
23:13:59.406 URL request 'https://pod-000-1042-17.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001042_t0019' returned an error: Post https://pod-000-1042-17.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001042_t0019: x509: certificate signed by unknown authority
23:15:08.635 URL request 'https://pod-000-1042-15.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001042_t0009' returned an error: Post https://pod-000-1042-15.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001042_t0009: x509: certificate signed by unknown authority
This has something to do with the root certificates on your machine. What OS are you running and has it been recently updated?
Windows 7 Pro and it runs updates every day.
Their SSL certificate is signed by Go Daddy Root Certificate Authority - G2. Can you run certmgr.msc to see if this certificate is included in the trusted root certificates?
Yes it is.
Make sure that root certificate is enabled for Server Authentication. On my Windows machine once I disabled that I got the exact same error x509: certificate signed by unknown authority.
Where would I find that option at?
It’s enabled same error.
Do you happen to have an https proxy or a firewall that blocks that certificate? Can you try open this url in Chrome: https://pod-000-1041-02.backblaze.com/b2api/v1/b2_upload_file/2568b8213d5e79405bc9051b/c001_v0001041_t0005? If the certificate works it should give you something like:
"code": "method_not_allowed",
"message": "Only POST is supported, not GET",
"status": 405
If you’re using IE, it won’t give your this message because of the 405 status code.
Firewall was blocking it, it’s working now. Thank you for the help.
Thanks for reporting back. Let me know if the backup works.
