Hi! I have a serious memory usage problem with the web edition when it does checks and prunes. For a while I’ve had the problem where every morning when I go back to the computer (which is always on) I find some apps closed and the dialog on my Mac saying that the system ran out of memory. Finally I figured it out… it’s Duplicacy! I have a schedule configured to do a check+prune task on both my local backup and the copy to Wasabi at 5am. I have triggered it manually and the memory usage climbed towards the end to almost 20GB of memory before I stopped it!! (I have 24GB total)
I am happy I found the cause but how do I fix it? I came to check if there’s a new version but the latest is still the 0.2.10 which is what I am using.
Can you please advice? Thanks in advance!
can’t deduplicate those so every new snapshot will re-add them. Since you backup every 15 minutes (i imagine you also backup your
