Hello,
I have two different Macs that use the same Microsoft OneDrive folder as storage. They use the same one-token.json file and the things used to be fine for several months.
Since some days ago, one of my Macs is no more able to refresh the one-token.json file, where the other works as usual.
This is some output from the bad Mac:
Mac-di-Ale:~ gpz500$ duplicacy list
Storage set to one://duplicacy-storage
Post https://duplicacy.com/one_refresh: x509: certificate has expired or is not yet valid; retry after 604 milliseconds
… while the good one goes without any problems with the same (just copied) one-token.json file.
With the one-token.json file just refreshed by the good one even the bad one, for some time (circa one hour) is working. Then it doesn’t work any more as before.
Other info:
both are using Duplicacy 2.5.2; the bad one has macOS 10.11.6 (El Capitan) while the good one has 10.15.5 (Catalina)
Thank you for your support!
