Migrating from rsnapshot
If I use duplicacy to back up a drive to backblaze containing rsnapshot backups, will this cause the data volume to explode? And can I expect this to be mitigated by Duplicacy’s deduplication?
From what I understand, rsnapshot uses linux hard links. When the files are moved or copied to an incompatible file system, the hard links break and duplicate files are created. Given there are ~30 snapshots in the backup history, this could create an absurd amount of data to upload.
The rsnapshot backups total 8.5TB on disk. I’d appreciate any insight from the community before I potentially upload 250TB of data to backblaze by accident. Thanks!
As far as I understand, rsnapshot is a front end for rsync.
I don’t think duplicacy will preserve hardlinks, it will treat each instance as separate file, but since content it identicall the data will occupy space only once.
Yeah, it uses cp with hard links to cascade the backups, then rsync to pull the new data.
I guess we’ll see how efficient Duplicacy’s deduplication is when I run this. Fingers crossed!
