Whenever I have Duplicacy running on my Mac, my monitors never turn off (which they usually do when I walk away from the computer for 10 minutes)
Can you run this command in the terminal to see if Duplicacy is blocking the sleep:
pmset -g assertions
When Duplicacy is running a backup, it will prevent the computer from going into sleep, so you will see a line like:
pid 83516(Duplicacy): [0x0004433f00058ab2] 00:00:16 NoDisplaySleepAssertion named: "Duplicacy running"
But that line should disappear as soon as the backup finishes.
Ok. That is what is happening. I get not having the computer sleeping, but I am not sure why the displays have to remain on to do that.
I should have used kIOPMAssertionTypeNoIdleSleep instead of kIOPMAssertionTypeNoDisplaySleep. Will fix this in the next update.
This has been fixed in version 2.0.1.
Thanks! Works great now!
